RSPAN and Local SPAN combination is not working
csdinesh18
could someone please confirm if RSPAN will work with the below config for capturing traffic from vlan 5-6 on both switches?
SW2
monitor session 1 source vlan 5 - 6
monitor session 1 destination remote vlan 99
SW1
monitor session 2 destination interface Fa0/45 - 46
monitor session 2 source remote vlan 99
server for capturing traffic is  connected on sw01 port 45-46. RSPAN from sw02 is working. but we're unable to see traffic for vlan 5 from sw01.
vlan configuration, allowing vlan in uplink are already in place. is this configuration correct?
we saw that we cannot use same destination port for two sessions
but here, we're passing the traffic from session 1 to 2. And then only pointed towards destination ports.. will this also be considered as two sessions?
georgehewittuk1
Have you configured the remote span vlan on both and with remote-span command on vlan?
