connect Router fa with L3 Switch gig
daniel4579329
hi
i have router with fa and L3 switch with gig
so i tried to connect them and change the speed of the gig to 100mb (like the fa on the router )
but i cant get the ports to up/up
Giuseppe Larosa
Hello @daniel4579329 ,
try to use speed auto the switch should be able to autodetect the speed of the other device.
You need also a straight cable not crossover between a router interface and a switch interface.
Hope to help
Giuseppe
balaji.bandi
try speed nonegotiate.  or post both the device config along with the models.
BB
Some gig interfaces can negotiate and use lower speeds. And some gig interfaces just do gig and not slower. We need more information about the switch and the switch interface so that we might know whether negotiation was possible.
Rick
it is not on portfast edge mode ( its on P2p )
