Running Config not available
estelamathew
Level 2
Level 2
Hello
For 1 of the switch it show's me running config not available,Please have a look at the attached.
5 Replies 5
estelamathew
Level 2
Level 2
Any hints ???? please
Do you know if the device is on?
You are user have privilege for see the configuration..... otherwise dont see configuration.
username name1 privilege 15
Greetings
I m a privilege 15 user and  the device is running.
Hello Dears,
The problem is not yet solved,pls help
