07-29-2020 11:40 AM - edited 07-29-2020 11:41 AM
Recent I changed my home wifi router with Rv340
when I checked my internet speed, the speed is reduced
Does this happen due to any router settings
Isp directly connected to router wan
3 vlan configured
Solved! Go to Solution.
08-01-2020 08:53 AM
I agree with @balaji.bandi that we do not have much information to work with. We might be able to give better advice if we knew how your RV router is configured, what features it enables, what was the speed with your home router and what speed are you getting with your RV router.
I would also suggest that you look into the possibility of a duplex mismatch (one device in full duplex and the other device in half duplex) checking both your device to RV and RV to provider.
07-29-2020 04:47 PM
what kind of speed link here, what happens when you connect directly to the internet with your PC that works as expected.
Do you have any IPS/ more advance FW feature enabled, disable and check.,
also, let us know what firmware it has?
=====️ Preenayamo Vasudevam ️=====
08-01-2020 08:53 AM
