RV345 multiple VLANs through one hardware port
Chainz111
I have this scenario
I have two VLANs 192.168.123.0 and 192.168.122.0
one cable running from the router to a managed TP-Link T1600G-52TS switch from this switch cables are running to multiple rooms in one room there is only one cable and one hardware socket than connects to a plain switch which distributes the connection to multiple servers on different VLANs some on 123 and some on 122 also one of them is connected to 123 VLAN and it has virtual machines also running 122 VLAN.
Is there a way to make two VLANs pass through one port with this router and setup?
marce1000
 - Check if this thread can help you :
           https://community.cisco.com/t5/small-business-routers/rv340-trunk-port/td-p/3215255
 M.
