S0/0/0
lucad7846
I am trying to configure a router as per the attached table.
I am struggling to find a router which has int s0/0/0 - I checked all the available routers and various modules that you can install in PK. However, I can't find any which has s0/0/0.
Some modules have int s0/3/0 or something similar, but none of them have s/0/0/0
Am I missing something?
Any suggestion would be much appreciated.
Cheers
2 Accepted Solutions
S0/x/Y
x is slot number you add the Serial Card,
here in your example there are Fastethernet in slot 0 and slot 1 and then you add Serial in slot 2
this make router show serial card number
s0/2/Y
that it.
you can apply same config only change the card number
take the 2901 router and install the HWIC-2T module in the slot to the right (file attached).
13 Replies 13
select any router from PKT, go to Card and if you have only Fastethernet, add Serial Card.
Thanks for getting back to me.
When you say go to Card - where is Card option located?
I can't find it
Many thanks
physical NIM-2T give you two serial port
Thanks for that
I did as you suggested but still unable to get to int s0/0/0
Screenshots attached
the card number is different from router to router
do
show ip interface brief
see the number of card and use it in config.
Thanks so much for your patient.
I need to have int s0/0/0 as per screenshot table in the first post.
I installed the module you suggested did show ip int brief but the serial int is not there.
Please see photo attached
I found a different module with serial int but they are s0/2/0 and s0/2/1 as per attached photo.
I don't understand why there is no s0/0/0. Most pkt labs have it
S0/x/Y
s0/2/Y
that it.
I can't thank you enough for your help.
So one last thing please. How do I apply the configuration and change the card number so that it shows s0/0/0? This is not clear - I have never done it before so I am a bit lost. Please bear with me
Many thanks
only instead of
interface  s0/0/0
use
interface s0/2/0
But that is my issue. I have to complete a lab and I must use the serial int as per the provided table.
So there is no way to get s0/0/0?
Hi Georg
Thanks so very much!!!! It worked. You're a life saver
Many thanks
Cheers
