Sampled NetFlow - V9 export
linker.team
Level 3
Level 3
I have a Cisco 2811, configured with random sampled netflow. I have enabled NetFlow V9. In the options template, I am not seeing the SAMPLING interval field. Is there any spefic config has to be done to include the SAMPLING info in options templates?
yjdabear
What about the "sampler" keyword?
I have configured the sampling. I dont have any issues on that. I am not able to see the SAMPLING INTERVAL and SAMPLER ID field in the exported V9 packets. How to include them?
Raj
ip flow-export {destination {ip-address | hostname} udp-port | source {interface-name} | version {1 | [{5 | 9} [origin-as | peer-as] [bgp-nexthop]]} | template {refresh-rate packets | timeout-rate minutes} [options {export-stats | refresh-rate packets | sampler | timeout-rate minutes}]}
sampler
(Optional) When Version 9 export is configured, this enables the export of an option containing random-sampler configuration, including the sampler ID, sampling mode and sampling interval for each configured random sampler.
