Save Running Config Via Web UI "save" icon? SG350X-48MP
Jinkees333
Hi, Sorry if this is a noob question but I have had a search.
When I make a change in the  web UI and hit save, a pop up message appears "Syslog Notification Information): %COPY-I-FILECPY: Files Copy -source URL running-config destination URL flash://system/configuration/startup-config"
This means that my change is saved to the start up config right?
When I google how to copy this, I do not get any solutions that involve the web ui. I can copy via telnet no problem, but need to know the whether I can rely on this ui method.
Thank you for reading.
EDIT: This question is regarding a SG350X-48MP
marce1000
          >...This means that my change is saved to the start up config right?
                     Yes,
 M.
7 Replies 7
 Which devie we are talking about?   Any Cisco device which allow me save using web UI, works normally.
Thank you, but I do not understand your reply. "works normally"- I am asking, what is the expected behaviour here? Does using the save icon over write the start up config?
balaji.bandi
Not sure waht device you working on here, give us more information about your environement before you posting the error or issue, we can understand easily and suggest accordingly.
most of the device configuration save idevice, the path you mentioned not able to recollect here.
BB
Apologies for the lack of specificity. My presumption was that this question would apply to cisco switches in general.
I am working on a SG350X-48MP.
I do not understand the second sentence in your reply. Please clarify.
yes as per the model concern the config is saved.
BB
marce1000
                     Yes,
 M.
Thanks!
