SCCP Unknown sessions
agup
Beginner
Beginner
We have a problem where the SCCP get stuck in 'UNKNOWN' / 'inactive' state. we run 'show sccp conn' command to check it manually. Looking for a script where we check for 'UNKNOWN' / 'inactive' sessions every hour, if there are 'n' number of sessions, then it would send out SNMP trap. Example output shown from 'sh sccp conn' command -
#sh sccp conn
sess_id    conn_id      stype mode     codec   sport rport ripaddr conn_id_tx
53645003   50656921     conf  inactive UNKNOWN 31106 0     UNKNOWN
53667104   50665149     conf  inactive UNKNOWN 16976 0     UNKNOWN
53671501   50666736     conf  inactive UNKNOWN 32456 0     UNKNOWN
Total number of active session(s) 3, and connection(s) 3
Thanks in advance...totally new to EEM scripting.....
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Okay, then you can do this using an applet.
event manager applet sccp_watch
event timer watchdog time 3600
action 1.0 cli command "enable"
action 2.0 cli command "show sccp conn"
action 3.0 set i 0
action 4.0 foreach line $_cli_result "\n"
action 4.1  regexp UNKNOWN $line
action 4.2  if $_regexp_result eq 1
action 4.3   increment i 1
action 4.4  end
action 4.5 end
action 4.6 subtract $i 2
action 4.7 if $_result ge N
action 4.8  snmp-trap strdata "The number of UNKNOWN SCCP sessions is $_result"
action 4.9 end
6 Replies 6
Joe Clarke
What version of code is your router running?
IOS is 15.1.M4
Joe Clarke
action 3.0 set i 0
action 4.4  end
action 4.5 end
action 4.9 end
thanks Joseph, it works. The only difference I had to make was the following to match my requirements, thanks a lot to you and this forum.
action 3.0 set i 0
action 4.1  regexp inactive $line
action 4.4  end
action 4.5 end
action 4.6 if i ge N
action 4.7  snmp-trap strdata "The number of inactive SCCP sessions are $i"
action 4.8 end
Joe Clarke
I assume you also changed the 'N' in action 4.6 to the actual value of problem sessions, correct?
yes, that's right. N was changed to a value.
Recognize Your Peers
