01-05-2009 05:46 AM
I'm trying to upgrade a router with CiscoWorks RME using SCP. It fails and says " SCP: [22 -> x.x.x.x:28475] send Privilege denied.".
The privilege level for this user is 15. I have checked the firewall and it's not blocking the traffic. Any ideas on where the privilege denied comes from? Thanks.
Solved! Go to Solution.
01-05-2009 11:12 PM
Here is a sample TACACS+ config:
! AAA authentication and authorization must be configured properly for SCP to work.
aaa new-model
aaa authentication login default group tacacs+
aaa authorization exec default group tacacs+
! SSH must be configured and functioning properly.
ip ssh time-out 120
ip ssh authentication-retries 3
ip scp server enable
See http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ftscp.html for more details.
01-05-2009 09:28 AM
What does your config look like? For SCP, you need a standard SSH config (which grants the user level 15 access) as well as:
What I typically use for local authentication and authorization is:
aaa new-model
aaa authentication login default local
aaa authorization exec default local none
username USER privilege 15 password PASS
01-05-2009 11:05 PM
Here's my aaa config, I'm using authorization but I don't see any logs in my ACS when RME attempts to use SCP.
aaa authentication login default group tacacs+ local enable
aaa authentication enable default line group tacacs+ enable
aaa authorization config-commands
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
ip ssh version 2
01-05-2009 11:07 PM
You need to be using exec-level authorization. You have authorization only for config-commands and commands. See my example config.
[Edit]
When the user logs in, they should be immediately dropped to a '#' prompt. The "show privilege" command should indicate they have level 15 access.
01-05-2009 11:12 PM
aaa new-model
ip ssh time-out 120
01-06-2009 02:36 AM
Thanks Joe, this was exactly what was missing,
aaa authorization exec default group tacacs+,
it now works perfectly.
03-23-2016 05:50 PM
For non-TACACS configs, this config also works:
aaa authorization exec default local if-authenticated
12-09-2018 10:21 PM - edited 12-09-2018 10:26 PM
Hi JOY,
I am also facing same problem.Actually, when I try to run SCP command from CMD it is showing privilege denied. I have configure device according to your post.
we are using ACS tacacs server for aaa, have privilege 15 access also.
we have logged in the device using SSH successfully.
ERROR:-C:\Users\Administrator>scp [email protected]:running-config .
password:
Authentication succeeded. Your password will expire in 1 weeks + 1 days + 3 hou
rs + 31 Minutes
Privilege denied.
Connection to 10.192.10.97 closed by remote host.
Please provide the solution ASAP.
Deependra
01-16-2024 04:35 AM
You also need to make sure you have enabled aaa authentication and authorization on the vty lines.
11-24-2026 07:36 AM
Hello all,
After I search for a solution about this issue, the fix was:
I don't understand why the soltuion with "tacacs+" group was shown here when you have only local accounts for the devices!
