script tcl for sync settings router HSRP
r-barbosa
Hi all,
I development the script tcl for syncronize the settings two router in mode hsrp. Follow bellow
proc gerar_configuracoes {
  set confs_nat [ exec "show running-config | include nat" ]
  set confs_acl [ exec "show running-config | include access-list" ]
  set confs_hsrp_outside [ exec "show running-config interface fastEthernet 0/0 | inc standby" ]
  set confs_hsrp_inside [ exec "show running-config interface fastEthernet 0/1 | inc standby" ]
  set acl_confs "access-lists_confs.txt"
  set nat_confs "nat_confs.txt"
  set hsrp_confs "hsrp_confs.txt"
  set FileAclId [open $acl_confs "w"]
  set FileNatId [open $nat_confs "w"]
  set FileHsrpId [open $hsrp_confs "w"]
  puts $FileAclId $confs_acl
  puts $FileNatId $confs_nat
  puts $FileHsrpId $confs_nat
  close $FileAclId
  close $FileNatId
  close $FileHsrpId
My idea is generate file with commands, with this script the file with commands is generate. Now how go sync the settings?
I thought of using rcmd rsh but with running the command "rsh 192.168.0.3 /user command" does not allow me to run the command "configure terminal" then run the commands themselves. any ideas
Regards.
2 Accepted Solutions
Joe Clarke
To do configurtation in tclsh, use "ios_config".  For example:
ios_config "int fa0/0" "shut" "end"
The ios_config command is a Tcl function, not an IOS command.  So, you need to wrap it within a Tcl script.  For example, assume you have a Tcl script like (call it config.tcl):
Then your rsh command would be:
rsh 192.168.0.3 /user cisco tclsh config.tcl
Joe Clarke
I trying the command.
R1#rsh 192.168.0.3 /user cisco ios_config "int fa0/0" "shut" "end"
Line has invalid autocommand "ios_config "int fa0/0" "shut" "end""
R1#
the command worked
R1#rsh 192.168.0.3 /user cisco show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.1.1            41   0000.0c07.ac01  ARPA   FastEthernet0/1
Internet  192.168.0.2            58   ca00.0ef8.0008  ARPA   FastEthernet0/0
Internet  192.168.1.3             -   ca02.0ef8.0006  ARPA   FastEthernet0/1
Internet  192.168.1.2            31   ca00.0ef8.0006  ARPA   FastEthernet0/1
Internet  192.168.0.3             -   ca02.0ef8.0008  ARPA   FastEthernet0/0
Internet  192.168.1.20            -   ca02.0ef8.0006  ARPA   FastEthernet0/1
R1#
Any idea
