Scripting & Nexus5000
gnijs
Level 4
Level 4
Hi all,
Does the Nexus5000 support any kind of scripting (ie. EEM or some other UNIX shells maybe?)
Is it on the roadmap for some future version ?
regards,
Geert
6 Replies 6
Joe Clarke
Seems to be only Nexus7000. Nexus 5000 does not show any eem information.
While that document is for the N7K, the configuration guide for the N5K point to EEM being available:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/fm/ov.html#wp1160864
Unfortunately, I do not have access to an N5K to verify.  If you do, you should be able to easily test the "event manager applet" command in config mode.
mmm...no success:
XXXXX(config)#  event ?
% Invalid command at '^' marker.
XXXXX(config)# event manager ?
XXXX(config)# event manager applet ?
XXXXX(config)# event manager applet
Running version 4.1(3)N2(1a) with the following features enabled:
Software
  BIOS:      version 1.3.0
  loader:    version N/A
  kickstart: version 4.1(3)N2(1a)
  system:    version 4.1(3)N2(1a)
  power-seq: version v1.2
  BIOS compile time:       09/08/09
sh feature
Feature Name          Instance  State
fcsp                  1         disabled
tacacs                1         enabled
fc-port-security      1         disabled
fabric-binding        1         disabled
port_track            1         enabled
npiv                  1         disabled
lacp                  1         enabled
npv                   1         disabled
interface-vlan        1         enabled
private-vlan          1         disabled
udld                  1         enabled
vpc                   1         enabled
cimserver             1         disabled
fcoe                  1         enabled
fex                   1         enabled
Further research has led me to believe that the Fabric Manager blurb may be wrong, and EEM is not on the N5K.  I am checking with the product team to be sure.
I have confirmed the N5K does not yet support EEM.  Support is being planned for a future release, however.  The documentation on Cisco.com has now been corrected.
