SDWAN 8200 Edge t edit attach device template and change device value
kevin-panogari
Hello all, can someone help my case.
First of all, my router losing all routing configuration because restarting, I check it's cause of PowerOn.
So I push template manually by CLI mode. When I want to change back to Vmanage Mode it's showing this error message.
Failed to update configuration - /ncs:devices/device{vedge-C8200-1N-4T-mySN}/config/ios:native/logging/console-config/common-config/console/discriminator/name (value "auth"): discriminator must be created at first, deleted last
0 Replies 0
