ā01-24-2011 03:19 AM
A few days ago a secondary power supply failed on a Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M) running Version 12.2(44)SG1.
We did see the syslog notification.
Jan 14 20:40:27.359: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
SNMP traps envmon are enabled.
snmp-server enable traps envmon fan shutdown supply temperature status
I dont understand why there was no SNMP trap sent ?
IOS: cat4500-entservicesk9-mz.122-44.SG1.bin
SW-SIM-GNV-01#sh power
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-1300ACV AC 1300W good good good
PS2 PWR-C45-1300ACV AC 1300W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 609 1050
Inline Power (-50V) 0 691
Backplane Power (3.3V) 0 0
Total 609 (not to exceed Total Maximum Available = 1300)
ā01-29-2011 04:15 PM
Support for the ciscoEnvMonSuppStatusChangeNotif trap was added to 12.2(44)SG, so it should be sent. It is controlled by the "envmon status" keyword (which it looks like you also have). Please post your entire SNMP configuration.
ā01-31-2011 02:16 AM
The device is monitored by SNMP polling etc using SNMP is working.
But appearantly SNMP traps triggered by the device itself are blocked by somekind of FW or ACL i didnt think about this because the device was polled using SNMP so i figured couldnt be a FW or ACL issue.
Thank you for youre effort !
The thread can be closed.
