Send MAIL TCL not working
mcamocardi
Hi guys, can you help me to send an email on a track event?
I am trying to send an e-mail on a track state change and I am having problems; follows some outputs:
IOS: flash:c1841-advipservicesk9-mz.151-3.T4.bin
R-1841#sh event manager version
Embedded Event Manager Version 3.20
Component Versions:
eem: (v320_rel1)1.0.8
eem-gold: (v320_rel1)1.0.0
eem-call-home: (v320_rel1)1.0.0
R-1841#more flash:mail2.tcl
::cisco::eem::event_register_syslog occurs 1 pattern ".*list boolean.*"
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
set mail_pre "Mailservername: marcelo@xxx.com.br:password@177.73.xxx.xxx\n"
append mail_pre "From: marcelo@xxx.com.br\n"
append mail_pre "To: marcelo.xxx@gmail.com\n"
append mail_pre "Cc: \n"
append mail_pre "Port: 587\n"
append mail_pre "Subject: LINK DOWN\n"
append mail_pre "Teste\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
if [catch {smtp_send_email $mail_msg} result] {
    error $result $errorInfo
event manager directory user policy "flash:/"
event manager policy mail2.tcl
Dec 13 16:04:49: %TRACKING-5-STATE: 1 list boolean or Down->Up
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: Process Forced Exit- MAXRUN timer expired.
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:     while executing
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: "if [catch {smtp_send_email $mail_msg} result] {
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:     error $result $errorInfo
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: }"
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:     invoked from within
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: "$slave eval $Contents"
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:     (procedure "eval_script" line 7)
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: "eval_script slave $scriptname"
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: "if {$security_level == 1} {       #untrusted script
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:      interp create -safe slave
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:      interp share {} stdin slave
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:      interp share {} stdout slave
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: ..."
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
Dec 13 16:05:13: %HA_EM-6-LOG: mail2.tcl: Tcl policy execute failed:
I removed the event manager policy and reaplyed.
I tested the smtp server on port 587 and it works.
25 Replies 25
You haven't renamed any of the functions.  Technically, you can remove everything from the library except the namespace definition and the smtp_send_email and smtp_connect functions.  Change the name of these functions to ::cisco::lib::my_smtp_send_email and ::cisco::lib::my_smtp_connect respectively.  In the new my_smtp_send_email function, change the call to smtp_connect to my_smtp_connect.
Then load your new library into your user library directory.  While flash: is fine, you should create a subdirectory to hold library files (e.g., flash:/eem_lib).  Then reconfigure your user library directory.  Then change your EEM policy to call my_smtp_send_email, and everything should work.
Hi Joseph. I was wondering if there is anyway I can edit the file tmpsys:/lib/tcl/smtp_lib.tcl
What would really solve my problem is to make this smtp_lib connect to port 587 instead of port 25.
When I try to do it I get a permission denied:
R-2801#copy tftp://10.0.0.10/smtp_lib.tcl tmpsys:/lib/tcl/
Destination filename [/lib/tcl/smtp_lib.tcl]?
Accessing tftp://10.0.0.10/smtp_lib.tcl...
Loading smtp_lib.tcl from 10.0.0.10 (via FastEthernet0/1): !
%Error opening tmpsys:/lib/tcl/smtp_lib.tcl (Permission denied)
Can I make this copy somehow?
No, you'll have to modify the file and create a new module.  The tmpsys location cannot be touched directly.
In my head, to solve this I should have nameespace like this, but I don´t know how to write this:
::cisco::eem::event_register_syslog occurs 1 pattern ".*1 list boolean or.*"
namespace import ::flash::custom_smtp_lib.tcl
Also, somehow I could temporarelly change the tmpsys:/lib to rw and update the smtp_lib.tcl but there is no such chmod command.
Hi Joseph,
This is what I did:
FILE mail2.tcl:
namespace import ::cisco::lib::my_smtp_send_email
namespace import ::cisco::lib::my_smtp_connect
set mail_pre "Mailservername: marcelo@xxx.com.br:xxx@177.73.xxx.xxx\n"
append mail_pre "To: xxx@gmail.com\n"
append mail_pre "Subject: Link Virtua DOWN\n"
if [catch {my_smtp_send_email $mail_msg} result] {
FILE custom_smtp_lib.tcl:
# SMTP client Tcl Library.
# Dec. 1999, Yu Zhang
# Copyright (c) 1999-2003, 2005-2008 by cisco Systems, Inc.
# All rights reserved.
namespace eval ::cisco::lib {
  namespace export smtp_subst my_smtp_send_email
  # messages corresponding to SMTP reply codes
  variable reply_code_str
  set reply_code_str(211) "System status, or system help reply"
  set reply_code_str(214) "Help message"
  set reply_code_str(220) "Service ready"
  set reply_code_str(221) "Service closing transmission channel"
  set reply_code_str(235) "Authentication successful"
  set reply_code_str(250) "Requested mail action okay, completed"
  set reply_code_str(251) "User not local; will forward to some forward-path"
  set reply_code_str(334) "Password"
  set reply_code_str(354) "Start mail input; end with ."
  set reply_code_str(421) "Service not available, closing transmission channel"
  set reply_code_str(450) "Requested mail action not taken: mailbox unavailable"
  set reply_code_str(451) "Requested action aborted: local error in processing"
  set reply_code_str(452) "Requested action not taken: insufficient system storage"
  set reply_code_str(500) "Syntax error, command unrecognized"
  set reply_code_str(501) "Syntax error in parameters or arguments"
  set reply_code_str(502) "Command not implemented"
  set reply_code_str(503) "Bad sequence of commands"
  set reply_code_str(504) "Command parameter not implemented"
  set reply_code_str(550) "Requested action not taken: mailbox unavailable"
  set reply_code_str(551) "User not local; please try forward-path"
  set reply_code_str(552) "Requested mail action aborted: exceeded storage allocation"
  set reply_code_str(553) "Requested action not taken: mailbox name not allowed"
  set reply_code_str(554) "Transaction failed"
# Write a message 'msg' to the given smtp socket 'sock'.
# Possible error raised:
#           None.
proc ::cisco::lib::smtp_write { sock msg } {
  ::cisco::eem::smtp_debug "smtp_write" "$msg"
  puts $sock "$msg"
  flush $sock
  return
proc ::cisco::lib::smtp_write_nodebug { sock msg } {
  puts $sock "$msg"
  flush $sock
  return
# Synchronously read one line from the  given smtp socket 'sock'.
#           None.
proc ::cisco::lib::smtp_read { sock } {
  set t [gets $sock k]
  if { $k == "" && $t == -1} {
      return -1
      ::cisco::eem::smtp_debug "smtp_read " "-1"
  ::cisco::eem::smtp_debug "smtp_read " "$k"
  return $k
# Check the reply code of the given connection. If it is not successful,
# raise an error with the corresponding error message. Also used to
# synchronize the request and reply.
proc ::cisco::lib::smtp_chk_reply { sock succ_code } {
  set r [ smtp_read $sock ]
  if {$r == -1} {
      return -code error "Socket closed by remote server"
  set k [lindex $r 0]
  if {$k != $succ_code} {
      return -code error [concat From SMTP server: $r\n$reply_code_str($k)]
  return
# Given the text of an email template file with all global variables
# Try to open a socket to any of the candidate mail servers.
# Return the first socket successfully opened.
# 1. $sock closed by remote server
# 2. $sock reply code is $k instead of the service ready greeting
# 3. cannot connect to all the candidate mail servers
proc ::cisco::lib::my_smtp_connect { svrlist srcipaddr srcintname} {
  global _username _userpass
  set num_retries 4
  set retry_delay 3000
  set l [llength $svrlist]
  for {set attempt 1} {$attempt <= [ expr $num_retries + 1 ]} {incr attempt} {
      ::cisco::eem::smtp_debug "my_smtp_connect" "attempt $attempt"
      for {set i 0} {$i < [ expr $l ]} {incr i} {
          set svr [lindex $svrlist $i]
  # parse svr field which can be
  # username:password@host
  # username@host
  # host
          regexp {(.+@)?(.*)$} $svr match uidpwd svrhost
          regexp {(.+\:)?(.*)$} $uidpwd match a1 a2
          #  $a2 will be the uid if no password specified
          if { $a1 != "" } {
              set uid $a1
              set pwd $a2
          } else {
              set uid [string trimright $a2 @]
              set pwd ""
  set _username [::base64::encode [string trimright $uid :] ]
  set _userpass [::base64::encode [string trimright $pwd @] ]
          if {[info exists sock]} {
              unset sock
          if { $srcipaddr != "" } {
              catch [set sock [ socket -myaddr $srcipaddr $svrhost 587 ]]
          } else {
              if { $srcintname != "" } {
                  set srcipaddr [ intf_get_ip $srcintname $svrhost ]
              } else {
                  catch [set sock [ socket $svrhost 587 ]]
          if {![info exists sock]} {
              continue
          if [catch {smtp_chk_reply $sock 220} result] {
              return -code error $result
          return $sock
      if {$attempt < [ expr $num_retries + 1 ]} {
          after $retry_delay
  return -code error "cannot connect to all the candidate mail servers"
# Disconnect the given socket.
proc ::cisco::lib::smtp_disconnect { sock } {
  smtp_write $sock "QUIT"
  if [catch {smtp_chk_reply $sock 221} result] {
  return
# Given an email template file 'email_template' , substitute each global
# variables in the file by its user-defined value. Return the text of the
# file after substitution.
# 1. cannot open email template file
# 2. cannot close email template file
proc ::cisco::lib::smtp_subst { f } {
  if [catch {open $f r} result] {
      return -code error "cannot open email template file: $result"
  } else {
      set fid $result
  set stxt [read $fid]
  if [catch {close $fid} result] {
      return -code error "cannot close email template file: $result"
  # using subst to replace optional args
  # need to eval on top level to get the values of user defined args
  set dtxt [uplevel #0 [list subst -nobackslashes -nocommands  $stxt]]
  return $dtxt
# already substituted, send the email out using SMTP protocol. The
# email template specifies the candidate mail server addresses, To
# addresses, Cc addresses, From address, subject line and email body.
# 1. wrong 1st line format
#    usage: Mailservername:
# 2. wrong 2nd line format
#    usage: From:
# 3. wrong 3rd line format
#    usage: To:
# 4. wrong 4th line format
#    usage: Cc:
# 5. error connecting to mail server:
#    $sock closed by remote server
#    (where $sock is name of the socket opened to the mail server)
# 6. error connecting to mail server:
#    $sock status code is $k instead of 220
#    (where $sock is name of the socket opened to the mail server,
#          $k is the reply code of $sock)
# 7. error connecting to mail server:
#    cannot connect to all the candidate mail servers
# 8. Host name is not configured
# 9. Domain name is not configured
#10. Any of the error message for non-OK SMTP reply code.
#11. error disconnecting from mail server:
proc ::cisco::lib::my_smtp_send_email { etxt } {
  global _domainname _username _userpass
  regsub -all "\r\n" $etxt "\n" etxt
  set linelist [split $etxt \n]
  # Below, be sure that mailsvrline, fromline, toline and
  # ccline can't have leading or trailing spaces
  # 1st line must be "Mailservername: ..."
  set svrline [string trim [lindex $linelist 0]]
  set svrlist [split $svrline { }]
  set len [llength $svrlist]
  if { [lindex $svrlist 0] != "Mailservername:" } {
        return -code error "wrong 1st line format. \nusage: Mailservername: "
  #delete the first item
  set svrlist [lreplace $svrlist 0 0]
  # 2nd line must be "From: ..."
  set fromline [string trim [lindex $linelist 1]]
  set fromlist [split $fromline { }]
  set len [llength $fromlist]
  if { [lindex $fromlist 0] != "From:" || $len != 2} {
        return -code error "wrong 2nd line format. \nusage: From: "
  set smtpsender [lindex $fromlist 1]
  # 3th line must be "To:" list
  set toline [string trim [lindex $linelist 2]]
  set tolist [split $toline \ ,\t]
  if { [lindex $tolist 0] != "To:" } {
        return -code error "wrong 3rd line format. \nusage: To: "
  # delete the first item
  set tolist [lreplace $tolist 0 0]
  # 4th line must be "Cc:" list
  set ccline [string trim [lindex $linelist 3]]
  set cclist [split $ccline \ ,\t]
  if { [lindex $cclist 0] != "Cc:" } {
        return -code error "wrong 4th line format. \nusage: Cc: "
  set cclist [lreplace $cclist 0 0]
  # 5th line optional. Can be "Sourceaddr:" or "Sourceintf:"
  set srcline [string trim [lindex $linelist 4]]
  set srclist [split $srcline { }]
  set srcaddr ""
  set srcintf ""
  if { [lindex $srclist 0] == "Sourceaddr:" } {
      set srcaddr [lindex $srclist 1]
      set linelist [lreplace $linelist 4 4]
  } else {
      if { [lindex $srclist 0] == "Sourceintf:" } {
          set srcintf [lindex $srclist 1]
  # compute receiver list
  set dest_list [concat $tolist $cclist]
  # connect to the mail servers and get a useful socket
  if [catch {my_smtp_connect $svrlist $srcaddr $srcintf} result] {
                return -code error "error connecting to mail server:\n$result"
  } else {
            set ssock $result
  # on this sock, send mail file to all the receivers
  set l [llength $dest_list]
  set k [llength $linelist]
  set hostname [info hostname]
  if {[string match "" $hostname]} {
    return -code error "Host name is not configured"
  if {![info exists _domainname]} {
    return -code error "Domain name is not configured"
  smtp_write $ssock "HELO $hostname.$_domainname"
  if [catch {smtp_chk_reply $ssock 250} result] {
  if {[string length $_username]} {
smtp_write $ssock "AUTH LOGIN $_username"
        if [catch {smtp_chk_reply $ssock 334} result] {
if {[string length $_userpass]} {
      smtp_write $ssock "$_userpass"
      if [catch {smtp_chk_reply $ssock 235} result] {
  smtp_write $ssock "MAIL FROM:<$smtpsender>"
    set smtprcver [lindex $dest_list $i]
    smtp_write $ssock "RCPT TO:<$smtprcver>"
        continue
  smtp_write $ssock "DATA"
  if [catch {smtp_chk_reply $ssock 354} result] {
  # write the body
  # write the date line
  smtp_write $ssock "Date: [clock format [clock seconds] \
-format "%d %b %Y %H:%M:%S %Z"]"
  # construct message id and write the message id line
  # Even there are multiple smtp clients running, the possibility
  # of same message ids are rare because in message id, we get
  # the time since bootup precise to nsec.
  array set stamp_since_boot [::cisco::eem::fts_get_stamp]
  set time_str [clock format [clock seconds] -format "%Y%m%d%H%M%S"]
  append time_str "." $stamp_since_boot(nsec)
  smtp_write $ssock "Message-ID: <$time_str@$hostname.$_domainname>"
  set debugbuffer ""
  # write the subject, from, to, cc and message data
  for {set j 1} {$j < [ expr $k ]} {incr j} {
     smtp_write_nodebug $ssock [lindex $linelist $j]
     append debugbuffer [lindex $linelist $j]
     append debugbuffer "\n"
  ::cisco::eem::smtp_debug "smtp_write" "$debugbuffer"
  smtp_write $ssock "."
  if [catch {smtp_disconnect $ssock} result] {
return -code error "error disconnecting from mail server:\n$result"
  return
R-1841# mkdir flash:eem/
R-1841# copy ftp://10.0.0.3/Publico/mail2.tcl flash:eem/
R-1841#copy ftp://10.0.0.3/Publico/custom_smtp_lib.tcl flash:/eem/
R-1841#dir flash:eem/
Directory of flash:eem/
   11  -rw-         627  Dec 20 2013 16:36:16 -03:00  mail2.tcl
   12  -rw-       12421  Dec 20 2013 16:40:16 -03:00  custom_smtp_lib.tcl
64012288 bytes total (19165184 bytes free)
R-1841#dir
Directory of tmpsys:/eem_lib_user/
  138  -r--       12421                      custom_smtp_lib.tcl
  137  -r--         627                      mail2.tcl
conf t
no event manager directory user policy "flash:/eem/"
no event manager directory user library "flash:/eem/"
no event manager policy mail2.tcl
int lo0
no shut
OUTPUT:
%HA_EM-6-LOG: mail2.tcl: unknown namespace in import pattern "::cisco::lib::my_smtp_send_email"
%HA_EM-6-LOG: mail2.tcl: "namespace import ::cisco::lib::my_smtp_send_email"
Don't change the namespaces in your policy.  Those should still be:
Everything else looks right.
We are almost there:
int lo0
no shut
Now I have this output:
%TRACKING-5-STATE: 98 ip sla 98 state Down->Up
%HA_EM-6-LOG: mail2.tcl: invalid command name "my_smtp_send_email"
%HA_EM-6-LOG: mail2.tcl: "my_smtp_send_email $mail_msg"
This is the mail2.tcl now:
R-1841#more flash:eem/mail2.tcl
Try this version and the accompanying tclIndex file (both need to go in your user library directory).  Then add the following import to your policy:
namespace import ::custom::lib::*
I got this now:
Directory of flash:/eem/
   11  -rw-         662  Dec 20 2013 18:44:00 -03:00  mail2.tcl
   12  -rw-        8893  Dec 20 2013 18:42:26 -03:00  custom_smtp_lib.tcl
   13  -rw-         625  Dec 20 2013 18:42:02 -03:00  tclIndex
int lo0
no shut
: %LINK-3-UPDOWN: Interface Loopback0, changed state to up
: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
: %TRACKING-5-STATE: 98 ip sla 98 state Down->Up
: %HA_EM-6-LOG: mail2.tcl: error connecting to mail server:
: %HA_EM-6-LOG: mail2.tcl: "my_smtp_send_email $mail_msg"
This means that the router is having issues establishing a TCP connection to port 587 on your mail server.  From the router itself, can you telnet to port 587 on that server?
