Separation of WEB traffic for webui and auth-proxy on router csr1000v
JohnJudi
Hi friend
I've configured auth-proxy on my csr1000v router.
But each time I use router's IP address in my browser, the webui page appears.
I want to see the page of web authentication proxy.
How can I separate these two pages?
OR
Can I disable webui interface without using "no ip http server" command?
Thank you in advance for your answer
 Never saw this feature before but you may need to use a different port instead 80 or 443. Any service that rely on web service will be down if you disable http services.
Hello
Thanks for reply
I entered the following commands:
parameter-map type webauth global
type webauth
http port 2900
and in the output of "show parameter-map type webauth global", HTTP port didn't change.
How exactly can I change the port number?
