Serial Numbers with CiscoWorks LMS 3.2
carles.segui
Hi all,
Is there a way to find the Serial Numbers of all your Cisco devices using CiscoWorks LMS 3.2?
Thanks in advance,
Carles
Joel Monge
You can run a hardware report under RME > Reports > Report Generator > Inventory > Hardware Report.  However, some devices are not aware of their serial number electronically.  In these cases, you can add the serial number using the "snmp-server chassis id" command so that RME can pick it up.  You can check this link with details on how the serial number is obtained via SNMP.
Joel Monge
Thanks Joel for the information
