Set up TACACS on Nokia
1pgordo
 You want to use ISE to set up TACACS on Nokia 7750 SR, does it work?
Ruben Cocheno
@1pgordo
yes you can, perhaps you need to check the Documentation from Nokia related to TACACS
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Mark Elsen
 - Ref : https://documentation.nokia.com/cgi-bin/dbaccessfilename.cgi/9300710901_V1_7750%20SR%20OS%20System%20Management%20Guide%2010.0R1.pdf
     Look for Enabling TACACS+ Authentication with find in your browser ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Ruben Cocheno
@1pgordo
I remember somebody else asking this question a while ago. Check if the thread below can help you.
https://community.cisco.com/t5/network-management/set-up-tacacs-on-nokia-equipment-using-ise/td-p/5004958
