Setting up DSL Connection
Ab_72
Community Member
Hi, I'm fairly new to packet tracer and have been familiarising myself with certain connections, one of them is DSL.  I understand how it works and functions but just wanted to ask for step by step instructions  via packet tracer on how to set a dsl connection.
M02@rt37
Hello @Ab_72,
First, you'll need at least two devices: a DSL modem and a router. You can add other devices for testing, but these two are essential for a basic DSL connection.
Connect one end of router's cable to one of the Ethernet ports (e.g., FastEthernet) on the DSL modem.
Router's basic cinfiguration:
interface FastEthernet0/0
no shutdown
ip dhcp excluded-address 192.168.1.1
ip dhcp pool DSL_POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
--This configuration assigns an IP address to the router's FastEthernet interface and sets up a basic DHCP pool for the DSL connection.
Configure now DSL Modem. This configuration may vary depending on the specific DSL modem model you're simulating. In a real-world scenario, DSL modems are usually provided and configured by the ISP.
Note that in PT, the DSL modem configuration might be limited or not available, so you can typically leave it as is.
Test from router: #ping 8.8.8.8
References:
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://m.youtube.com/watch%3Fv%3DcN6KUxpXUiw&ved=2ahUKEwip9oPkspiCAxVxRaQEHTiKDTQQwqsBegQIEhAG&usg=AOvVaw3VW9-e6TKnA3UWhNHLTZSs
https://honim.typepad.com/biasc/2014/02/how-to-use-a-dsl-modem-to-connect-to-a-simulated-internet-in-packet-tracer.html
Best regards
How to configure dsl modem in cisco packet tracer. | How to create cloud with dsl modem. | how to configure or connect modem with pc/laptop. | Stay connected with onlinelearnnkp.blogspot.com for more related videos.| videos by niraj kumar.| niraj kumar. #telecom . #networking. #dsl modem in cisco
