14.3 Create a LAN ipconfig/all command not working
diegolan
Hi everyone, how's it going?
In the Part 3 of this activity, on Step 1, when I enter the ipconfig/all command to see other host's information I get the Invalid command error message. Does anybody know why is this happening?
Here's the section https://skillsforall.com/launch?id=f393c38f-b410-4d2b-8275-70e144273519&tab=curriculum&view=217bd1e7-98c1-5d77-8745-e1b6477735cd
2 Accepted Solutions
@diegolan you need space between command parts.
try 'ipconfig /all'
Good luck
KB
Martin L
it should be enter the ipconfig /all command -space before /
Regards, ML
**Please Rate All Helpful Responses **
try 'ipconfig /all'
Good luck
KB
Martin L
Regards, ML
diegolan
Thanks guys, I appreciate it.
