Setting Up Expired Certificate Allowance for ISE
CCC3
The test is in progress by generating an expired certificate and importing it to your PC.
Regarding eap-tls during ise setup
'Allow Authentication of expired certificates to allow certificate renewal in Authorization Policy'
There's a setting like this.
I understood that this setting allows authentication even if the client's certificate expires.
However, I imported the expired certificate and checked the setting, but it was not authenticated.
When you attempt to access the SSID,
'I can't connect because I need a certificate to log in. Contact your IT support representative.'
The phrase is displayed and there is nothing left in the live log of ISE.
I understood that this is not a failure to authenticate in ise, but that the expired certificate itself is judged by pc not to have a certificate.
If you test or actually use any place regarding the corresponding setting of ise, please share it.
marce1000
 @CCC3   - We see notice that you are firing lots of question in the community about various topics. Could you narrow that down in the future to real issues on your daily work which affect your business. To spare time for volunteers and their contributing efforts,
 Tx  - M.
