Setting up FMC over KVM on WSL
nomorenoless
Hello guys,
After a long battle with wsl I was able to made it run the FMC on a KVM machine in Ubuntu WSL however here is where my limits end, I cannot made pass network to the KVM on the management IP example: 192.168.2.2 and I have created a bridge interface br0
my netplan scryopt is as:
network:
  version: 2
  renderer: NetworkManager
  ethernets:
    eth0:
      dhcp4: yes
  bridges:
    br0:
      interfaces: [eth0]
      dhcp4: no
      addresses:
        - 192.168.2.2/24
      gateway4: 192.168.2.1
      nameservers:
        addresses:
          - 8.8.8.8
 after sudo netplan apply I run command:
ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet 10.255.255.254/32 brd 10.255.255.254 scope global lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000
link/ether 00:15:5d:1a:bd:0e brd ff:ff:ff:ff:ff:ff
4: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 52:54:00:7f:91:2e brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
5: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
6: br0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
inet 192.168.2.2/24 brd 192.168.2.255 scope global noprefixroute br0
inet6 fe80::4c4b:16ff:fec2:1ff6/64 scope link
and also I ran the command ip route show
default via 192.168.2.1 dev br0 proto static metric 425
192.168.2.0/24 dev br0 proto kernel scope link src 192.168.2.1 metric 425
192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 linkdown
and yet still do not connect the WSL network to my management network, PLEASE HELP
nomorenoless
 ping 192.168.2.101 (LOCAL WINDOWS 11 IP ON MANAGEMENT INTERFACE)
From 192.168.2.101 icmp_seq=1 Destination Host Unreachable
