Setting VTP Domains and Modes
aseychell
How can VTP domains and vtp modes (Server,CLient,Transparent) be configured through the CiscoWorks interface?
I have been trying to find the component of ciscoworks to edit this config but have succeeded only through CLI.
ankurbhasin
Level 9
Level 9
Hi Friend,
Using the VTP-VLAN buttons, you can set up the VTP domain, mode, and other parameters.
Check this link with graphical view which will help you locating the VTP-VLAN buton.
http://www.netcraftsmen.net/welcher/papers/cwsi.html
HTH, if yes please rate the post.
Ankur
The problem is that I dont have those buttons available in campus manager. I have LMS2.5 updated till 10th March.
I cannot find those options.
Can you please guide me.
