copying configuration
davidcruise
i have cisco switch 6513 ,when i telnet to it & make show running ,the configuration is too much that i can't take it with"copy & paste"so is there any method in cisco works to take the text of the telnet to a textfile
5 Replies 5
nhabib
Level 9
Level 9
If the device is properly managed in RME, chances are you already have a copy of the config on your CiscoWorks server.
What version of CiscoWorks are you running? On what platform (Windows or Solaris)?
i use ciscoworks common services V2.2
and on WINXP platform
Take a look at the following location on your CiscoWorks server:
CSCOpx\files\archive\shadow
In there, you will see a number of folders under which reside the latest configs that RME has captured.
balajitvk
Level 4
Level 4
Hi David,
If u want to take a copy of running config, u can do it with cisco works.
Even with some telnet clients like "Tera Term" you can take the running configs.
http://hp.vector.co.jp/authors/VA002416/teraterm.html
Rgs,
Balaji.
ankurbhasin
Level 9
Level 9
Hi David,
You can also take the backup of your config via cli command to your tftp server.
Incase you are running CATOS
copy config tftp
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_5/cmd_ref/d_cmd.htm#wp1025320
Incase you are running Native IOS.
copy run tftp:
Ankur
