02-03-2022 02:53 PM
I am using SG300-20 switches (and other dash numbers) as Layer 2 switches.
In some cases, I need a VLAN for management - so I assign some ports to those VLANs and the other ports for the functional network role for which the switch is intended.
I expect that once I've configured the VLANs, they will stay that way.
But, they don't any more... ports VLAN memberships change and the switch stops working.
How can I use the SG300-20 as just a simple, managed switch again?
02-03-2022 04:40 PM
have you saved the config, is the config lost due to reboot ?
Try disabling macro and test it : (make sure you always save the config)
=====️ Preenayamo Vasudevam ️=====
02-03-2022 05:54 PM
Thanks for the information!
I do wish this whole thing were more an additive option rather than an ugly surprise!!
02-03-2022 11:59 PM
Agreed, but this is what it is..maybe you as a customer can send an email for improvements or feature requests if you like.
