SG500 Swith Python Telnet Script error
JCubio
Community Member
Hi All,
I'm trying to connect to our switch via telnet using script. It's just a basic script to change the hostname. But everytime I run the scrip I get an error.
import getpass
import telnetlib
HOST='192.168.0.2'
user = input("Enter your remote account: ")
password = getpass.getpass()
tn = telnetlib.Telnet(HOST)
tn.read_until(b"Username: ")
tn.write(user.encode('ascii') + b"\n")
if password:
    tn.read_until(b"Password: ")
    tn.write(password.encode('ascii') + b"\n")
    tn.write(b"conf t\n")
    tn.write(b"hostname SW-Core1\n")
    tn.write(b"exit\n")
    tn.write(b"write\n")
    print(tn.read_all().decode('ascii'))
File "C:\Users\jcubio\AppData\Local\Programs\Python\Python38-32\lib\telnetlib.py", line 317, in read_until
    self.fill_rawq()
  File "C:\Users\jcubio\AppData\Local\Programs\Python\Python38-32\lib\telnetlib.py", line 526, in fill_rawq
    buf = self.sock.recv(50)
ConnectionResetError: [WinError 10054] An existing connection was forcibly closed by the remote host
I tried telneting to the switch using putty and cmd and it was successful. I also tried the script in a gns3 environment and it was successful.
What would be the issue in this case? Please advise
Thank you
balaji.bandi
Add debug and see what is wrong on the script
tn.set_debuglevel(1000)
BB
5 Replies 5
balaji.bandi
BB
Hi Sir @balaji.bandi,
Debug shows it's passing the "User Name:" instead of "Username:" but in the script it is
Telnet Debug:
Telnet(192.168.0.2,23): recv b'\r\nUser Name:'
What should I change in the script?
Thank you very much
balaji.bandi
Can you post completely debug output as an attachment to understand better, please?
BB
It works now. The issue is the spacing. Instead of
tn.read_until(b"Username: "), The telnet prompt is
tn.read_until(b"Username:").
Thanks for the help sir.
balaji.bandi
No worries, some time it happens blank space, depends on the editor you use - notepad ++ is good.
Glad all working as expected. and thank you marked as a solution.
BB
