show ip flow top-talkers
Natha340Mai340
Hello everyone, I wish see the top talkers 10 at the my router 2800 IOS 12.4 (13a)
but when I run the command "show ip flow top-talkers" appear following:
% Top talkers not configured
I've set
Router(config)#ip flow-top-talkers
Router(config-flow-top-talkers)#top 10
I'm using the netflow version 9
maybe my router not support this issue ?? or it's missing some configuration ?
thank
yoongseong
Hi Maicon,
Under "ip flow-top-talkers", you need to configure "sort-by" as it's required to run top-talkers command.
Yoong Seong
yoongseong
Hi Maicon,
Yoong Seong
Thank you yoonseong,
I haven't made the test yet. but I think your suggest will be work
