show ip sockets output
dmayne
When I run the show ip sockets from the CLI on a Cat 3500XL switch, I get some unexpected results.
On 3 switches that are interconnected, there is a client device (10.2.73.45) that shows a connection to port 33521. These entries show up everyday when I perform the query. Does anyone know what might be going on here - what I can check on the client pc (I plan on running a netstat)
nycs-s200101#show ip sockets
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 0.0.0.0 123 10.2.72.10 123 0 0 1 0
17 10.2.73.45 33521 10.2.72.10 161 0 0 1 0
17 10.2.90.128 514 10.2.72.10 51153 0 0 0 0
vladrac-ccna
Level 5
Level 5
161 indicates that this host is accessing your switch on SNMP services.
could be a monitoring device? cisco works?
HTH,
if it does, Id appreciate if you rate this post.
Vlad
Vlad,
Thank you for this response. The ip address in question is actually a client machine. This device should not be monitoring our switches. Do you know of a way to disconnect this from the switch side?
If its port 161 then its polling the switch via the read or read-write community strings. You could either change the comm strings (may not be feasible) or put an access-list on the community strings preventing that client from polling the switch.
