Show IP traffic collected with SNMP
catalindominte
Does anyone know if the statistics displayed by the command "show ip traffic" can be collected via SNMP and the graphed?
Actually I am after a way to find out how to graph the number of packets that are punted to the CPU via SNMP, and show IP traffic command gives a good picture of that.
Any other ideas?
Thank you
Catalin
richardbergen
better late than never I was looking for the same answer and came across this page. Dug into it a bit more and found this really good article someone else wrote with the answer:
http://www.force10networks.com/CSPortal20/TechTips/0040_HighCPU.aspx
