unable to connect to LMS 4.1 web interface
liviu.tudorache
hello
I have a new installed LMS 4.1 application on a virtual machine. First everything was ok but now I’m unable to access the application via web interface … but the ssh connection is working just fine.
It is my fist LMS installation and I need some help
Thanks!
Michel Hegeraat
Level 7
Level 7
check the pdshow to see what parts of LMS are running
check if apache is running if not check eventlog why not
check this document:  https://supportforums.cisco.com/docs/DOC-14520
cheers
Michel
Michel Hegeraat
Level 7
Level 7
cheers
Michel
Hello Michel
The apache server was shut down (in don’t know why?!):
       Process= Apache
       State = Administrator has shut down this server
       Pid   = 0
       RC     = 0
       Signo = 0
       Start = 06/20/12 19:24:48
       Stop   = 06/20/12 19:24:48
       Core   = Not applicable
       Info   = Application started by administrator request.
After restart off apache server, I’m back in business.
Thanks for your time and help!
Best regards,
Liviu
This is nice but it is for Windows only I have installed this on a VMware sever using Linux redhat 64 byte this Doc does not help
For Soft Appliance version you can start by checking the status from the basic cli. If you need to restart a specific process and don't want or need to restart the whole application ("application start LMS"), you need to drop into the OS shell and issue the pdexec command.
Here is an example (using pipe to include to abbreviate output and the pdexec command to show verbose process status at the OS cli):
SecLab-LMS/admin# show application status LMS | i Apache
  Apache                Running normally                          5674
SecLab-LMS/admin# shell
Enter shell password :
Starting shell...
[SecLab-LMS/root-ade ~]# pdshow Apache
        Process= Apache
        State  = Running normally
        Pid    = 5674
        RC     = 0
        Signo  = 0
        Start  = 04/23/13 08:03:20
        Stop   = Not applicable
        Info   = Web Server initialized ok.
I'll add the above as a comment to the earlier linked document to aid other seekers.
