Bookmark
Subscribe
1056
Show run issues when using CML Breakout
Translator
Community Manager
Community Manager
Hello, while using CML I am also using CML with Windows Telnet using Breakout. But when I use the Show run command, it does not display everything. Does anyone have a solution to this problem?
10 Replies 10
can you post a screenshot ?
When I run do sh run as above, only part of the output is displayed and the rest is not displayed.
Maybe it's supposed to work this way?
Make sure your terminal emulator app that you use with Breakout has flow control disabled. If the app sends an x-off to throttle the terminal output, IOS will halt sending and will not give you the “more” prompt.
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
I'm doing this in Powershell and I don't see anything called flow control, should I use Putty?
check the value of the $FormatEnumerationLimit in PowerShell, the default is 4 I think:
PS C:\Users\powershelluser>$FormatEnumerationLimit
Change it to -1:
PS C:\Users\powershelluser>$FormatEnumerationLimit =-1
This method does not work.
What if you configure 'term length 0' on the Cisco before running PowerShell ?
I tried, but it didn't scroll and I could only see the very end.
in PowerShell, when you see the 'More', try and hit the '~' key (tilde, left of the '1'), this should be the equivalent of ENTER...
Putty works for me with Breakout.
