Shutdown interface based on power attenuation?
brriapol
Team,
Is it difficult to write a script which performs a shutdown on a Cat3650 interface once attenuation has reached >17dB (29.5 is current in the output below)?
Thank you,
Switch#show interface transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Gi1/1/1      29.4       3.30      -5.5     -29.5 --
This should work.
Joe Clarke
Do you mean < -17 db (i.e. abs(atten) > 17)?
You are correct.
This should work.
Joe,  incredible!  thank you very much for doing this so quickly.
