Simple MAC Address management
Tareq Rajabi
I am in an environment with about 300 workstations, all connected to stacked 3750 switches. I want to be able to do simple management on the MAC addresses allowed on each port without using the IOS manually or using complex scripts. Is there a GUI based manager that I can use from Cisco. I have looked up software like LMS4.0, but they seem too advanced for what I need to do.
All suggestions are welcome and thank you in advance
Martin Ermel
I am not sure what exactly you are looking for and what you want to do, but perhaps Cisco Network Assistant would be an option for you:
http://www.cisco.com/en/US/partner/products/ps5931/tsd_products_support_series_home.html
and here is the list of supported devices.
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp699844
