Simulate a Cisco SD-WAN potential attacks and vulnerabilities EVE-NG
sam1981
Can you explain how to create and run a threat scenario to simulate a Cisco SD-WAN potential attacks and vulnerabilities in EVE-NG simulator ?
balaji.bandi
Depends on the code you using as Controller and devices on the simulator.
you have many tools available like kali Linux like tools you use for testing's. (you can add one of the node kali linux when you simulating MPLS or Internet side and do the testing's)
BB
sam1981
Can you explain how you can test a DDoS Attack use case on a  EVE-NG simulator on a SD-WAN environment  please? or any suggestions please
This out of scope of this community - you have plenty documentation available over google how to simulate DDOS attack against devices.
as i mentioned kali linux does for you, also hping3  you can create tools box VM in the simulator lab.
BB
thank you for your response
