Slow speed with connect VPN
KangatharanRavi
Hellow AlI
use a Cisco MR42 with Any connect installed. I have a 50 Mbps Internet Feed, and when i connect to Any connect VPN, my speed is limited to around 2 Mbps.
How to fix this issue?
Thank you.
5 Replies 5
balaji.bandi
if this full VPN tunnel, then all the traffic go via main hub, if you like to use local internet not related to work, then you need to setup split tunnel.
BB
Hi Balaji.bandi
Thank you for your reply.
How to split tunnel? Could you please any some guidance?
Thank you very much.
balaji.bandi
Please test and advise how that goes.
BB
