smart agent communication error with smart licensing cloud
MarcoSlama5869
Visitor
Hi community!
I have a Cisco Smart Software Satellite(Versio 6.3.0)
It seems to me that the Synchronisation ist not working anymore/hanged up
The Synchornisation is still running since 4 days and does not finish
In the Firepower Management Center the Licenses are shown correctly but I get following error message
I have checked the ports on the firewall and i pinged the cisco cloud server. Both are ok
Has anyone an idea?
edftermoeletrica
Frequent Visitor
Frequent Visitor
You need to update your FMC, some root CA certificates have been decommissioned.
https://www.cisco.com/c/en/us/support/docs/field-notices/721/fn72103.html
pieterh
As I read this info you should have synchronized before 25-aug-2019, but that did not succeed
so on 28-aug-2019 smart license authorization expired.
i'd check under button "actions"  if you can kill the current synchronization and start a new one
edftermoeletrica
Frequent Visitor
Frequent Visitor
