02-01-2015 04:36 AM
Greetings,
Is there any way to add NTLM authentication in SMTP relay notifications in LMS 4.2.5? I'm aware of the direct way to add SMTP relay without any username and password, however i need it to be authenticated. Any help would be greatly appreciated.
Best regards,
Solved! Go to Solution.
02-01-2015 10:58 AM
Unfortunately LMS doesn't support Authenticated SMTP and hence you have to have an SMTP server/account for LMS which doesn't requires any authentication to relay messages.
-Thanks
Vinod
02-01-2015 10:58 AM
-Thanks
Vinod
