NCS will not start - Free disk space is too low and server will not be started.
max_gbp777
My NCS appliance will not start as the disk is full (95%). I can login as admin but unable to log in as root to check the directories nor change the root password.
I have also run ncs cleanup, but it did not resolve the issue.
Any assistance is appriciated.
Thank you,
Max
ncs/admin# root
% invalid command detected at '^' marker.
ncs/admin# ncs password root password TestCisco1!
CompilerOracle: exclude org/snmp4j/Snmp.send
Error Occured ::http://localhost:8080/xmp_data_handler_service/xmpDataOperationRequestServlet
ncs/admin# sh disks
temp. space 2% used (35884 of 1967952)
disk: 1% used (192204 of 127250060)
Internal filesystems:
  warning - /opt is 95% used (615427632 of 689715672)
ncs/admin#
ncs/admin# ncs status
Health Monitor is running, with an error.
Free disk space is too low and server will not be started. Used space percentage is 95%
Failure Server is Success
Reporting Server is Stopped
Ftp Server is Stopped
Database server is stopped
Tftp Server is Stopped
Matlab Server is Stopped
NMS Server is stopped.
Cisco Application Deployment Engine OS Release: 2.0
ADE-OS Build Version: 2.0.1.038
ADE-OS System Architecture: x86_64
Copyright (c) 2005-2010 by Cisco Systems, Inc.
All rights reserved.
Hostname: cr-ncs
Version information of installed applications
Cisco Prime Network Control System
Version : 1.1.2.12
0 Replies 0
