Bookmark
Subscribe
722
Sniffer software for LMS 2.6
eliaspaulos
I am trying to use sniffer trace between LMS server and a Router have communication problem with Ciscoworks.Which sniffer software is working easily and efficiently. any suggestion please.my LMS is on Sun Solaris 8.
2 Accepted Solutions
Joe Clarke
Snoop works well:
# snoop -o /tmp/outfile -s 1518 tcp port 23
However, LMS comes with a sniffer built in. You can find it in Device Center > Tools > Packet Capture.
wireshark -r file.jet
There's nothing special about the .jet file.
5 Replies 5
Joe Clarke
Snoop works well:
thank you so much. great utility!
And even though I didn't say it, Wireshark (http://www.wireshark.org) can be used to analyze the sniffer files from both snoop, and the LMS built-in sniffer.
thanks J. actually i did get the sniffer file from device center try to open on Wireshark. wire shark unable to open .jet file. could you help me how i can open the .jet file on wireshark to analyze?
