SNMP and Temperature
blmccreary
I changed the temp thresholds from their default value of around 54 to 23 degrees below the RED threshold making the YELLOW threshold 42.  Now when I do this:
#sh env st
SWITCH: 1
FAN is OK
TEMPERATURE is OK
Temperature Value: 47 Degree Celsius
Temperature State: YELLOW
Yellow Threshold : 42 Degree Celsius
Red Threshold    : 65 Degree Celsius
POWER is OK
RPS is NOT PRESENT
SWITCH: 2
FAN is OK
TEMPERATURE is OK
Temperature Value: 45 Degree Celsius
POWER is OK
RPS is NOT PRESENT
You can see that it says the temperature state is YELLOW.
Now when I poll SNMP this is what I get:
Temperature sensor 'SW#1, Sensor#1, GREEN ' is in 'Normal' state.
Current value: 47, threshold value: 65
Temperature sensor 'SW#2, Sensor#1, GREEN ' is in 'Normal' state.
Current value: 45, threshold value: 65
So I never get an alert that the switch is out of GREEN threshold.
I am using WhatsUp Gold V16.1.3 for my monitoring application.
The switches that this is occuring on are stacked 3750G's running c3750-advipservicesk9-mz.122-46.SE.bin IOS.
Thank you.
12 Replies 12
check whcih switches modules,
Sorry, I'm not sure what you mean.
Dear Brandon McCreavy,
I am using Cisco Prime Infratructure to monitor Stacked C3750, C2960, 6504E.
I even cannot get device's temperature.
Could you please share which specific MIB that you used to get Switch's temperature?
Thanks & Regards
Here are the MIBs that I am looking at
1.3.6.1.4.1.9.9.13.1.3.1.2
1.3.6.1.4.1.9.9.13.1.3.1.3
1.3.6.1.4.1.9.9.13.1.3.1.4
1.3.6.1.4.1.9.9.13.1.3.1.6
Thank you
Thank McCreary,
So all above OIDs are included in CISCO-ENVMON-MIB.
I know that I asked very basic question.
I used many NMS software, all of them display devices (cisco sw) temperature immediately however my Cisco PI 1.3 cannot display it.
Best Regards
please configure
like this
Snmp-server enable traps envmon fan shutdown supply temperature status
rate it,
Hi Aman,
Thanks.
But it not work for me.
Please take a look to my picture.
Best Regards.
See the configuration , and configure it
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps (eigrp, ospf like this)
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps ether-oam
snmp-server enable traps flash insertion removal
snmp-server enable traps cpu threshold
snmp-server enable traps rep
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps port-security
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps ethernet cfm alarm
snmp-server enable traps event-manager
snmp-server enable traps rf
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server enable traps mac-notification change move threshold
*Plz do rate this post if you found it helpful*
Thanks.
My problem is that the teperature is not display on Cisco PI 1.3.
Of course, if I use other Monitoring Software, I can easilly get this information by 02 ways: SNMP polling or TRAP as you suggest.
Best Regards
Anyone else please help?
Hi Cuong
PI should show temp. utilization by default in TOP N ENV TEMP dashlet.
Can you tell which devices are managed and their IOS version?
Dear Mahabir,
It does not work for me.
Please check help me:
Cisco Catalyst 2960S: Software  15.0(2) SE4
Cisco Catalyst 3750-X Stack Switch: Software: 15.0(2) SE4
Cisco Catalyst 6504-E (Used VSS): Software: 15.1(1) SY1
Thanks & Best Regards
Cuong
