SNMP-Engine causing High CPU Utilization
I have many routers Cisco 2901 and one router 2951 with IOS version 15, and some days ago these routers are having high CPU every 10 minutes caused by the process SNMP-ENGINE, I have three snmp servers in my network. How I can fix this issue.
Thanks for the help.
9 Replies 9
Rolf Fischer
Level 11
Level 11
Hi Adrian,
with COPP (control plane policing) you could rate-limit the amount of SNMP traffic, but this will most likely increase the response-times to the NMS.
Apart from that maybe you could optimize the polling behavior of your SNMP servers.
Maybe this documents are helpful to identify the cause: https://supportforums.cisco.com/docs/DOC-15956 http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800948e6.shtml
Hope that helps
Rolf
Vinod Arya
Most of the time these observed spikes are often genuine. As you have three NMS servers, you may want to check if they are colecting some data from devices which takes too much time to process to take a toll on CPU.
You may want to manually notice the incoming packets for snmp by :
show snmp | inc input
When CPU spikes collecting this would help to determine how many packets are hitting device.
If the command show snmp stats oid works you can share the output as well. And if all seems well, when the cpu is high share following details apart from above:
> Show proc cpu sort | exc 0.00
> show stacks (*You can collect SNMP ENGINE PID from show proc cpu command which has first column as PID.)
Example:
NMS-WL-6500#sh proc cpu | i SNMP
223     1575116   6003718        262  0.00%  0.51%  0.62%   0 SNMP ENGINE
With this you can run :
NMS-WL-6500#show stacks 223
Process 223:  SNMP ENGINE
  Stack segment 0x52056884 - 0x52059764
  FP: 0x52059688, RA: 0x416C9FE0
  FP: 0x520596B8, RA: 0x414D1234
With this we can check which specific oid is being stuck or taking cpu to max.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
I attach the outputs of commands when the CPU goes to 99%.
Thanks a lot for the help.
Thanks for details. it is very strange that the device is polling doesn't look very explosive from the show snmp stats oid.
May be some snmp process is stuck and hang and hence not constant on high CPU. I would need show version from device to check further on this.
Also, If something got hang in snmp process, it may be temporary, I would like you to try to restart the SNMP ENGINE Process.
It has usually no impact on device, except for a few seconds SNMP ENGINE STOPS and do not respond to any snmp packets unless restarted.
This is very simple procedure and doesnt even affects the snmp config. Following is the way to do it:
To Stop
# no snmp-server
To Start
# any snmp command which previously exist can be entered again to push the SNMP ENGINE to start.
Example:
Please do this and see if the SNMP ENGINE subsides after this.
-Thanks
I restarted the SNMP-ENGINE process in the way thath you say but the problem persists. I attach the output of show version command.
Hi Adrain,
It seems large Route and/or ARP Tables Polled by the NMS Station. The Network Management station queries routers for their entire route table to learn about
other networks. It uses this information to find other routers and query them about their
knowledge of networks around them. In this fashion, the management station can learn the
topology of the entire network.
The router stores the route table in a hashed format, more conducive to quick route
searches. However, SNMP responses for the route are required to be returned in
lexicographical order per RFC1213. Therefore, for each SNMP request the router receives,
the hash table must be sorted lexicographically before a SNMP response PDU can be built.
The larger the route table, the more CPU intesive the sort.
SNMP is a low priority process as far as the CPU scheduler is concerned, so another
process requiring CPU resources takes priority. Therefore, while CPU spikes occur in this
scenario, they should not affect performance.
It's possible for you to apply the procedure of blocking the routing and ARP tables
described in the following link and monitor the device?
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800948e6.shtml#l
arge_route
Please check once.
Hello Vinod,
I already configured the snmp views like the lecture recommend, but the problem persist it is very strange. This is the configuration of snmp in my routers:
snmp-server view cutdown iso included
snmp-server view cutdownat excluded
snmp-server view cutdown internet.6.3.15 excluded
snmp-server view cutdown internet.6.3.16 excluded
snmp-server view cutdown internet.6.3.18 excluded
snmp-server view cutdown ip.21 excluded
snmp-server view cutdown ip.22 excluded
snmp-server community comunity1 view cutdown RO 98
snmp-server community comunity2 view cutdown RO 98
snmp-server community comunityRW view cutdown RW 98
snmp-server ifindex persist
snmp-server location OC
snmp-server contact Administrator
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps config-copy
snmp-server enable traps cpu threshold
snmp-server enable traps syslog
snmp-server enable traps voice
snmp-server host 172.20.1.65 comunity2
The problem was solved, the solution was erase the read write snmp community. No one server was reanding this snmp community.
Thanks.
Glad to know the issue is fixed . This sounds strange that the RW string ws creating issue.
