SNMP for Temp inlet fan 3850
morph.andy
HI all
just wondered if someone can point me in the right direction.  We use SolarWinds as a monitoring tool, I'm trying to monitor the inlet sensor on a 3850, but cant seem to get granular enough with it.  The alert picks up all temperature alerts including the hotspot (attached). So now I'm thinking to just get the inlet temp I'm going to have to do it via the MIB - this is what I'm having trouble working out - I get some output on the switch for show SNMP mib - and can envtemp - but with 6 entries (we have 7 switch's) - anyone help with me finding this mib to get it to work with solarwinds ?
marce1000
  - You want to snmp-walk all oid's from the CISCO-ENVMON-MIB on the device , see if anything could be useful and or if the needed value is available.
 M.
balaji.bandi
try SNMP walk with OID - 1.3.6.1.4.1.9.9.91.1.1.1.1.4
Generic OID should work :
https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/13505-show-env-temp-c6500.html#overview_sensor
BB
