SNMP Group, User and Inform Setting
jon_panes24
Im somewhat confused with the SNMP Group and User settings.
For example you can create a SNMP group with a noauth setting and you can tie that group to a user that has authpriv settings
snmp-server group group-noauth v3 noauth
snmp-server user user1 group-noauth v3 auth md5 cisco priv 3des cisco
You can also reference that user belonging to a NoAuth group with SNMP Informs/traps that require authpriv
snmp-server host 192.168.1.1 version 3 priv user1 cpu
How does the order of operations here work?
pieterh
it's not really that confusing
your configured user user1 has the ability to use snmp with multiple authentication methods
- authpriv
- auth (nopriv)
- noauth
an account can be member of multiple groups
depending on the need of the snmp-server group
you can create a group that has only snmp-read rights with noauth
and another group that has snmp-write ricghts with authpriv
