SNMP ifmib ifindex values
Richard Pidcock
I have an ISR4331/K9 reporting incorrect ifindex values.
RTR-003-4331-01#show snmp mib ifmib ifindex Gi0/0/0
Interface = GigabitEthernet0/0/0, Ifindex = 1
RTR-003-4331-01#
Clearly the index values is 1, however my Netflow tools is discovering this as ifindex 16 which is a LAN side subinterface.
Has anyone seen this?  Recommendations?  Gi0/0/0 is a fixed port; reload the router?  It's only been up 16 weeks; thoughts?
Richard W. Pidcock
7 Replies 7
Mark Elsen
      - Recommendations are to check the current software version and use the latest advisory release , if applicable , especially if you are currently on an older version , (check if that helps)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
odd indeed. What if you configure 'snmp ifindex persist' on that interface ?
Richard Pidcock
I think I'm going to run a code upgrade on this device tonight and then I'll report back tomorrow to let you all know if any differences after upgrade and a reload.  Thanks
Richard W. Pidcock
RTR-003-4331-01#show snmp mib ifmib ifindex Gi0/0/0.1
Use subinterface to see ifindex' netflow detect interface pass traffic in case you config subinterface then it can subinterface detect traffic pass not main interface
MHM
It seems to be discovering an interface with index value 16, which is one of my wireless client device LAN subnets.  Accordingly the traffic I see under netflow stats align with that wireless subnet.  This is very strange indeed.
Richard W. Pidcock
Richard Pidcock
So I ran a code upgrade (Version 17.9.4a), still no good.  I'm going to reach out to the vendor of my NetFlow monitor tomorrow and see what they have to say.
Richard W. Pidcock
Richard Pidcock
So it turns out that this problem was caused by a nuance within the monitoring solution software (Manage Engine OP Manager).  It was holding on to some stale data in a database that was causing the weird issues with snmp ifindex values.  Thanks to all, now I've got my issue resolved.
Richard W. Pidcock
