SNMP MIB OID
omarmontes
Hi guys!
Just one questions, is there a way to get the OID of a MIB object directly from a Router?
I know i can get the Object Name from: show snmp mib, but how can you get the OID from ther router (witout having to check it online or with a snmp walk or something)
Thanks in advance!
Joe Clarke
Are you asking if you can get the object identifier value of an object name shown in "show snmp mib", or are you asking if you can perform SNMP GETs (i.e. to get the value of an SNMP object) directly from a router?
Excatly, the first one. im trying to get the OID from the Object name displayed on the "show snmp mib"
Unfortunately, this is not possible.  You would need to use an external tool like the SNMP Object Navigator at http://www.cisco.com/go/mibs .
