SNMP OID for active voice calls
ev1205
Level 2
Level 2
I have been trying to search for the correct SNMP OID / MIB to retrieve actual "active voice calls' on cisco router 2911 version 15.2(4)M5
We need to confirm if calls volume is exceeding contracted limit with ISP ( AT&T), causing call drops.
Thanks in advanced for your help
Enrique
AFROJ AHMAD
Hi Enrique,
I believe that the OID you are looking for is cpmActiveDS0s (OID -
1.3.6.1.4.1.9.10.19.1.1.4) part of CISCO-POP-MGMT-MIB. This object provides the number of
DS0s that are currently in use.
if you don't see the expected result, you may also try to use cvCallActiveDS0s (OID -
1.3.6.1.4.1.9.9.63.1.3.3) which is part of CISCO-VOICE-DIAL-CONTROL-MIB
other related OID's are :
Object: callActiveTable
OID: 1.3.6.1.2.1.10.21.1.3.1
Description: "A table containing information about active calls to a
specific destination."
Object: callActiveCallState
OID 1.3.6.1.2.1.10.21.1.3.1.1.9
Description "The current call state.
unknown(1) - The call state is unknown.
connecting(2) - A connection attempt (outgoing call) is being made.
connected(3) - An incoming call is in the process of validation.
active(4) - The call is active.
Object: cvCallActiveDS0s
 OID: 1.3.6.1.4.1.9.9.63.1.3.3
Description "The current number of DS0 interfaces used for the  active
calls."
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Afroz thanks a lot for your answer, these commands apply to CUBE router too, where we have a SIP trunk to ISP??
Thanks ia advanced for your answer
yes , OID's should be same. they should work fine
Thanks-
Afroz
Afroz....
THANKS a lot for your help !!!
