SNMP OID for IPSLA shows UP also if Operation failed
HUBERT RESCH
Level 3
Level 3
High , I used following test-applet to check perdiodically the status of ip sla 199
ip sla 199
icmp-echo 7.192.196.101 source-interface GigabitEthernet0/1
request-data-size 100
threshold 400
ip sla schedule 199 life forever start-time now
event manager applet test
event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.199 get-type exact entry-op ge entry-val "0" poll-interval 1 maxrun 200
action 100.0 if $_snmp_oid_val eq 1
action 110.0  set _sla199status "DOWN"
action 120.0 else
action 130.0  set _sla199status "UP"
action 140.0 end
it works fine if the ipsla show as result timeout which result in a value of 1 in the snmp-variable.
if I shutdown the source-interface of ip-sla there are differnt behaviours
on 7200 the
Latest operation return code: timeout
and the snmp-var is 1 which means down
on 3900e
Latest operation return code: Operational failed
and the snmp-var is still 2 which means up
Do I misunderstand anything or could it be a IOS-Bug
Hubert
Joe Clarke
The object 1.3.6.1.4.1.9.9.42.1.2.9.1.6 which is rttMonCtrlOperTimeoutOccurred.  If a timeout did not occur, then the value is expected to be 2 (false).  Therefore, what you're seeing is expected.  You might consider using 1.3.6.1.4.1.9.9.42.1.2.10.1.2.199.  If the value of this object is anything other than 1, then an error has occurred.
Joe Clarke
Thx for the response, in the meantime I found out myself. I was a little bit confused, because I
thought with M2 this is the correct behaviour (but it seems with M2 this was wrong behav
iour and with M3 now it works correct)
Hi HUBERT,
What is M2 or M3? Snmpv2 and snmpv3 or slot cards type?
Yossi avrahami
