SNMP OID OID_CSWSTACKPORTOPERSTATUS lost on IOS15
Leonid Voronkin
Hello, guys.
We use OID 1.3.6.1.4.1.9.9.500.1.2.2.1.1 on Cisco Catalist 2960S Stack with IOS 12.2.55SE9
snmpwalk -O n -c infraRO -v2c 192.168.137.231 1.3.6.1.4.1.9.9.500.1.2.2.1.1
.1.3.6.1.4.1.9.9.500.1.2.2.1.1.5138 = INTEGER: 1
.1.3.6.1.4.1.9.9.500.1.2.2.1.1.5139 = INTEGER: 1
.1.3.6.1.4.1.9.9.500.1.2.2.1.1.5141 = INTEGER: 1
.1.3.6.1.4.1.9.9.500.1.2.2.1.1.5142 = INTEGER: 1
But it lost on the same switch model on IOS 15.2.2E8
snmpwalk -O n -c infraRO -v2c 10.235.5.36 1.3.6.1.4.1.9.9.500.1.2.2.1.1
.1.3.6.1.4.1.9.9.500.1.2.2.1.1 = No Such Instance currently exists at this OID
Does anyone know if this has changed or been completely removed?
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
balaji.bandi
Do you have OID downloaded from here :
https://mibs.cloudapps.cisco.com/ITDIT/MIBS/servlet/index
BB
According to SNMP Object Navigator it must be the same.
But it is not
