SNMP OID to get MIB Nat Statistic on CRS (ver 5.3.0) and MIB VLAN / STP on Switch
somphong.p
Which OID to get MIB Nat Statistic on CRS (ver 5.3.0) and MIB VLAN / STP on Switch ?
Thank you
Somphong ,
It looks like the info is defined in CISCO-NAT-EXT-MIB, but there doesn't seem to be any software which supports it:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ciscoNATExtMIB
Also, keep in mind that there is currently no MIB that has the "show ip nat statistics" output. An enhancement
request was opened against this, but so far there are no plans to add this to the MIBs.
Here is the enhancement request ID and release notes:
CSCdr25202 no mib variable for ip nat statistics for total active translations
"snmp mib variable for the command: show ip nat statistics for the total active
translations is not present at the moment.
This is an enhancement request. The work-around is to issue the command on the device itself (via CLI)."
The other MIBs are the following :
CISCO-VTP-MIB : "The MIB module for entities implementing the VTP
protocol and Vlan management."
http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.46
CISCO-STP-EXTENSIONS-MIB : "The MIB module for managing Cisco extensions to
the 802.1D Spanning Tree Protocol (STP)."
http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.82
Hope it helps !
Claudio Gonzalez S
