SNMP OIDs for Routed Port Point to Point interface
Could you please share SNMP OIDs to check cisco switch Routed Port Point to Point interface up down status.
M02@rt37
hello @PrabakaranBalasubramanian16319,
OID: 1.3.6.1.2.1.2.2.1.8
https://cric.grenoble.cnrs.fr/Administrateurs/Outils/MIBS/?oid=1.3.6.1.2.1.2.2.1.8
Best regards
Thanks for sharing. I have checked and i see all access, trunk ports outputs are getting. I need to check only the interface UP/Down status  where the port configured as Point to Point configuration (routed port). Only Routed port need to checks.
